        On ExtremeSwitching switches, the port number is simply noted by the physical port
                        number.
    Separate the port numbers by a dash to enter a range of contiguous
            numbers, and separate the numbers by a comma to enter a range of non-contiguous
            numbers:
            - x-y—Specifies a contiguous series of ports on a stand-alone
                    switch.
            - x,y—Specifies a non-contiguous series of ports on a stand-alone
                    switch.
            - x-y,a,d—Specifies a contiguous series of ports and a
                    non-contiguous series of ports on a stand-alone switch.
                                - Port:Channel—For 4120, ExtremeSwitching 5720, 7520, and
                                        7720 channelized ports. For example, 49:4 maps to Port 49,
                                        Channel 4.
